Meine DPR läuft auch noch tadellos.
Bitchspeed 12oocc
- Boncho
- Käfer: 68er ex-Automatik
- Fahrzeug: Porsche 944 Turbo
- Fahrzeug: W201
Re: Bitchspeed 12oocc
Süßes Teil.
Aber deine hättest du ja ruhig mal mit hohlgebohrten Lagerstellen undn bisschen erleichtert bestellen können.
Finde ich auch:-D
- John Bitch
very nice crank, takes away one more part from the `break`list
when it looks to expensive it probably is
think it over again
think it over again
Yes indeed! I still have 3 of those on my 'to break' list: crank, rods and pistonsJesse hat geschrieben:very nice crank, takes away one more part from the `break`list
1192cc T1 N/A Challenger
- John Bitch
The biggest point on my breaklist are still the pistons. Torben is going to make first welding this weekend, I don`t think that I will get any sleep till monday
As I am going to use 5,6" or 5,7" CB H-rods (depending on the liners I am going for, 1200cc or 1300cc, I am not sure yet) , I am really confident that they will make it through the dyno and through a few starts at the tree
The clock, the clock...
Fuck off!
With N/A I don't think you have much to worry about with the welding if it stays dimentionally the same (roundness).
Tik, tak, tok...
5.7" rods would give you a rod-ratio of 2,26 which I think is more then Formula 1John Bitch hat geschrieben:
Tik, tak, tok...
- John Bitch
The roundness is the worry I have, Walter, the only worry I have for now.
I am still in discussion about the rod length with Peter, of course, and also with Torben Alstrup. The thing for me is that in no way I am going to use AA Liners, so it depends on how my used mahles are still in shape (have been refreshed approx. 500km ago) or not. If they are not, it is easier for me to get a set of 13oocc liners with 90mm foot diameter then 12oocc ones (which I would prefer cause no machining will be needed then). If I have to go for the 1300cc ones they will have to be machined anyway, so why not go for a longer rod then? I would een go for 5,8"
Fuck off!
- triker66
Hey gibt es das ganze auch in deutscher Sprache??????
Guess thats my fault, as said before, I can read or desipher german just fine so don't mind me.
It's writing a good sentence that`s hard for me.
Jesse
Jesse
Zuletzt geändert von Jesse am Fr 15. Feb 2013, 16:40, insgesamt 2-mal geändert.
think it over again
think it over again
- John Bitch
John Bitch hat geschrieben:I am fine with englishHelps me to learn...
Vee Dubs in da House:-D
Allein schon der Werbefilm ist Grund genug sich des Englischen anzulernen:-D
http://www.youtube.com/watch?v=xCIF6JF1O5U
Zuletzt geändert von Poloeins am Fr 15. Feb 2013, 17:08, insgesamt 1-mal geändert.
- John Bitch
Sorry:-D
