Aus thesamba ein toller Überblick über alle? Vergasernummern
https://www.thesamba.com/vw/forum/viewt ... ?p=5695407
Worldwide VW/Solex Carburetor Types, Carburetor Modification-State / Base Flange Numbers
Matching BOSCH Distributor numbers and stock carburetor jetting data.
For Upright Bug/Bus/Ghia/Thing 1200-1600 engines, Single-barrel carburetors
25HP and 36HP engines. Distributors listed are the listed factory originals, Old Bosch #s.
Carburetor
Type Matching
Distributor
Number Bug
Ghia
Bus Engine
Size Approx
date of
intro Main
Jet Air
Correct
Jet Pilot
Jet Notes
26VFI VE4BRS383 BUG 1131 1949 120 170 g45
26VFIS VE4BRS383 BUG+
BUS 1131 4/50 120 170
180 g45 (timed to 12.5BTDC)
28PCI VE4BRS383 BUG+
BUS 1131 10/52 105 200
190 g50 20mm venturi
(timed to 12.5BTDC)
28PCI VJ4BR2
VJ4BR3 BUG +
BUS 1200 12/53 122.5 200 g50 6.1:1 compression
22mm venturi
28PCI VJUR4BR8 BUG 1200 9/54 117.5 195 g50 6.6:1 compression begins
28PCI VJBR8 BUS 1200 9/54 117.5 195 g50
28PCI VJU4BR8
VJUR4BR8 GHIA 1200 8/55 117.5 180 g50
28PCI ZVJUR4R4 GHIA 1200 8/59 117.5 180 g50
28PCI ZVPAU4R1 GHIA 1200 1/60 117.5 180 g50
28PCI VJR4BR25
VJ4BR25 BUS 1200 5/59 117.5 180 g50
28PCI ? BUG 1200 8/60 117.5 195 g50 1961/newerStandard 36HP model only
1200 (40HP), 1300, 1500 and 1600 engines:
Modification State Number Carb
Type Matching
Distributor
Number Bug
Ghia
Bus Engine
Size Approx
date of
intro Main
Jet Air
Correct
Jet Power Fuel:
Jet Size and check ball Notes
Pilot jet usually (g)55 unless noted
Note: The Modification State number is stamped on the front-of-car side of the carb bowl on older
28PICT and 28PICT-1s, this was later moved to the base flange across from the throttle attachment
none yet 28PICT ZVPAU4R2 or
ZVPAU4R5 BUG 1200 8/60 122.5 130y 1.0 with ball
ZVPAU4R5 BUS 1200 6/60 122.5 145y 1.0 w/o ball
none yet 28PICT Ghia 1200 8/60 122.5 145y 1.0 w/o ball
none yet 28PICT ZVPAU4R5 BUS 1200 1/63 122.5 145y 1.0 w/o ball
none yet 28PICT ZVPAU4R5 BUS 1500 1/63 115 145y or
150z 0.70 w/o ball g45 pilot
VW 4-1(prod)
VW 8-1(spares) 28PICT-1 ZVPAU4R5 BUG 1200 11/63 122.5 130y 1.0 with ball
ZVJU4R3 2/64
VW 4-1(prod)
VW 8-1(spares) 28PICT-1 111905205M/N BUG 1200 8/64 122.5 130y 1.0 with ball
VW 12-1 28PICT-1 ZVPAU4R5 BUS+
Ghia 1200 11/63 122.5 145y 1.0 w/o ball
ZVJU4R3 2/64
VW 12-1 28PICT-1 111905205M/N BUS+
Ghia 1200 8/64 122.5 145y 1.0 w/o ball
VW 20-1
VW 22-1 28PICT-1 111905205M/N BUS 1500 11/63 115 150z 0.70 w/o ball g45 pilot
NOTE: 28PICT-1 VJUR4BR8 Dual Cyclone Filters - VW wanted a carb with no upper advance drilling
and to use a 141129301A carb (unknown base flange number)
BUG 122.5 170z NONE
BUS 130 130y
VW 45-1 30PICT-1 131905205 BUS 1500 8/65 115 135z 0.75 w/o ball 60 Pilot
VW 46-1 30PICT-1 113905205K GHIA 1300 8/65 125 170z 0.75 w/o ball Early style throttle return spring
VW 47-1 30PICT-1 113905205K BUG 1300 8/65 125 125z NONE Early style throttle return spring
VW 51-1 28PICT-2 111905205N BUG 1200 1/66 122.5 130y 1.0 with ball Late style throttle return spring
VW 51-1 28PICT-2 113905205K BUG
147 1200 8/66 122.5 130y 1.0 with ball Late style throttle return spring
VW 58-1 30PICT-1 113905205K BUG+
GHIA 1300 8/65 125 155z 0.75 w/o ball For to use with Dual Cyclone Air Filters
VW 60-1 30PICT-1 131905205 BUS 1500 8/65 117.5 135z 0.75 w/o ball 6V - 60 pilot
VW 75-1 30PICT-1 113905205K BUG 1300 12/65 125 125z NONE Late style throttle return spring
VW 77-1 30PICT-1 131905205 BUS 1500 8/65 115 135z 0.75 w/o ball 6V - 60 pilot
VW 78-1 30PICT-1 131905205 BUS 1500 8/65 115 135z 0.75 w/o ball 12V - 60 pilot
VW 80-1 30PICT-1 131905205 BUS 1500 8/65 117.5 135z 0.75 w/o ball 12V - 60 pilot
VW 81-1 30PICT-1 113905205K GHIA 1300 12/65 125 170z 0.75 w/o ball Late style throttle return spring
VW 83-1 30PICT-1 113905205K BUG 1300 8/67 125 125z NONE
VW 84-1 30PICT-1 131905205 BUS 1500 8/65 120 145z 0.75 w/o ball 6V lower compression - 60 pilot
VW 87-1 30PICT-1 131905205 BUS 1500 8/65 120 145z 0.75 w/o ball 12V lower compression - 60 pilot
VW 89-1 28PICT-2 113905205K BUG
147 1200 8/67 122.5 140z 0.75 w/o ball 6V
VW 104-1 30PICT-1 113905205K BUG 1500 8/66 120 125z 0.50 w/o ball 6V
VW 105-1 30PICT-1 113905205K BUG 1500 8/66 120 125z 0.50 w/o ball 12V
VW 106-1 30PICT-1 113905205K Ghia 1500 8/66 120 135z 0.50 w/o ball 6V
VW 107-1 30PICT-1 113905205K Ghia 1500 8/66 120 135z 0.50 w/o ball 12V
VW 126-1 30PICT-2 113905205M Bug 1500 8/67 x116 125z 0.60 w/o ball USA
VW 126-1 30PICT-2 113905205M Ghia 1500 8/67 x116 135z 0.60 w/o ball USA
VW 126-1/2 30PICT-2 113905205M
113905205T BUS 1600 8/67 x116 125z 0.60 w/o ball USA, Typ 2 1600, eng code B5000001-B5116436, M157(emission control)
VW 126-2 30PICT-2 113905205M
113905205T BUG 1500 3/68 x116 125z 0.60 w/o ball USA Manual
VW 126-3 30PICT-2 113905205T BUG 1500 2/69 x116 125z 0.60 w/o ball USA Manual
VW 132-2 30PICT-2 113905205K
113905205L
113905205T
113905205AB
113905205AC BUG 1300 2/68 X125 125z NONE Typ1 1300 from F1341000-F1778145
20/02/1968-30/07/1969
VW 137 30PICT-2 113905205K BUG 1500 8/67 120 125z 0.50 w/o ball Non-USA
VW 139 30PICT-2 113905205K Ghia 1500 8/67 120 135z 0.50 w/o ball Non-USA
VW 141-4 30PICT-2 IND INDUSTRIAL ENGINE
VW 146-1 30PICT-2 211905205N
211905205P BUS 1600 1/68 120 135z 0.65 w/o ball Non-USA From B0019736 to eng B286760 then went to VW 260-1
VW 164 30PICT-2 113905205P Bug 1500 9/67 120 125z 0.50 w/o ball Non-US Auto
VW 167-1 30PICT-2 113905205P BUG 1500 10/67 x116 125z 0.60 w/o ball USA Autostick
VW 167-2 30PICT-2 113905205P BUG 1500 3/68 x116 125z 0.60 w/o ball USA Autostick
VW 167-3 30PICT-2 113905205P BUG 1500 2/69 x116 125z 0.60 w/o ball USA Autostick
VW 169 30PICT-2 113905205P Ghia 1500 9/67 120 135z 0.50 w/o ball Non-US Auto
VW 171-1 30PICT-1 113905205K BUG 1300 8/67 125 155z 0.75 w/o ball
VW 172-1 30PICT-1 211905205N BUS 1600 8/67 120 135z 0.50 w/o ball Non-USA
211905205P BUS 1600 8/67 120 135z w/o ball Non USA 1600SP, Eng code B0000001-B0019735
VW 181-1 28PICT-2 113905205K BUG
147 1200 8/67 122.5 140z 0.75 w/o ball 12V Non USA
1970 Model Year and newer 28 through 34 PICT-2 PICT-3 and PICT-4 upright engines
(base flange #) Carb
Type Matching
Distributor
Number Bug
Ghia
Bus Engine
Size Approx
date of
intro Main
Jet Air
Correct
Jet Pilot
Jet
(G) Notes
(all PICT-3/4 carbs have a dual outlet power fuel system)
Note: On 30PICT-3, the Mod. State Number might be found stamped into the bowl of the carb next to the
volume and air bypass adjustment screws. The number was soon returned to the base flange location.
VW 226-1 30PICT-3 113905205T Bug 1600
SP 8/69 112.5 125z 65 Manual
VW 227-1 30PICT-3 113905205AD
113905205AE Bug 1600
SP 8/69 112.5 140z 65 Automatic
VW 228-1 30PICT-2 113905205K
113905205L
111905205T BUG
181 1500 8/69 X120 125z 55 Non-USA Bug(not ghia) H1 engine, from H 1124669
VW 228-1 30PICT-2 111905205T 181 1500 8/69 X120 125z 55 Non-US Thing
VW 236-1/2 30PICT-3 113905205M
113905205T BUS 1600
SP 8/69 X112.5 140z g65 Typ 2 1600, eng code B5116437-onward, M157(emission control)
VW 236-1/2 30PICT-3 113905205T BUS 1600
SP 1970 112.5 140z 65 USA (your “USA” spec is our M157 spec.. see above.)
VW 237-1 30PICT-2 113905205AC BUG 1300 8/69 X125 125z - Non-USA Manual F1 engine, from eng F1778146
VW 239-1 30PICT-2 113905205AC BUG 1300 8/69 X125 125z - Non USA Autostick F1 engine, from eng F1778146
VW 240-1 28PICT-2 113905205K
113905205L
111905205T
111905205AA from D0675001 BUG 1200 8/69 122.5 135z 0.75 w/o ball 12V Non USA
VW 241-1 28PICT-2 Same as 240-1 BUG
147 1200 8/69 122.5 135z 0.75 w/o ball 12V Non USA
VW 259-1 30PICT-2 113905205K
113905205L
111905205T Ghia 1500 8/69 X120 135z 55 Non-USA Ghia H1 engine, from H 1124669
VW 260-1 30PICT-2 BUS 1600 8/69 x116 125z 55 From B0286761
VW 263-1 30PICT-2 181905205 181 1500 8/69 X120 125z 55 M63 OPTION, MILITARY EQUIPMENT , SUPPRESSION
All engines from this point on are 1200 (SP) 1300DP or 1600DP
VW 279-1 34PICT-3 113905205AJ BUG 1600 1971 127.5 75z 60 USA Manual
VW 280-1 34PICT-3 211905205Q BUS 1600 1971 125 60z 57.5 USA
VW 281-1 34PICT-3 113905205AH BUG 1600 1971 130 75z 60 USA Autostick
VW 281-2 34PICT-3 113908205AH BUG 1600 1972 127.5 75z 60 USA Autostick
VW 281-3 34PICT-3 113908205AH BUG 1600 1972 127.5 75z 55 California autostick
VW 281-4 34PICT-3 113908205AH BUG 1600 1973 127.5 75z 55 USA Autostick
Generator accelerator pump
VW 281-5 34PICT-3 1139008205AH BUG 1600 1973 127.5 75z USA Autostick
Alternator accelerator pump
VW 282-3/4 31PICT-3 113905205AJ Bug 1300 1971 145 170z 60 Non-US manual Aux fuel jet-50, From Eng AB000001-AB350000
VW 283-1/2 30PICT-3 111905205AA Bug 1200 1971 112.5 170z Non-USA 1200 M88 M610
VW 284-1/2/3 30PICT-3 111905205AA BUG 1200 08/70 112.5 170w 55 Non USA 1200 6V
VW 289-1 34PICT-3 113905205AJ Ghia 1600 1971 127.5 75z USA Manual
VW 290-1 34PICT-3 113905205AJ Ghia 1600 8/70 X127.5 80z 60 USA Autostick
/M157(emissions-DVDA, M9(Auto), eng AE000001-AE558000
VW 290-2 34PICT-3 113905205AN Ghia 1600 8/71 X127.5 70z G55 M157(emissions-DVDA Dizzy), M9(Auto), eng AE558001-
VW 290-3 34PICT-3 113905205AH Ghia 1600 x127.5 70z 55 USA Autostick
VW 291-2 34PICT-3 113905205AJ Bug 1600 08/70 X145 130z 65 Non-US manual AD engine,
eng AD0000001-AD257543
VW 294-2 34PICT-3 113905205AJ Ghia 1600 08/70 X145 145z 65 Non-US manual AD engine,
VW 297-2 34PICT-3 113905205AK Bug 1600 08/70 X145 130z 65 Non-US autostick AD engine,
VW 298-2 34PICT-3 113905205AK Ghia 1600 08/70 X145 145z 65 Non-US autostick AD engine,
VW 299-1/2 34PICT-3 113905205AJ
211905205R Bus 1600 08/70 X140 120z G60 Non - US AD engine,
eng AD0000002-AD290640
VW 307-2/4 31PICT-3 113905205AJ Ghia 1300 1971 135 170z 60 Non-US manual Aux fuel jet-50
VW 310-2/3 31PICT-3 113905205AK Bug 1300 1971 145 170z 60 Non-US autostick Aux fuel jet-50
VW 311-2 31PICT-3 113905205AK Ghia 1300 1971 135 170z 60 Non-US autostick Aux fuel jet-50
VW 312-1/2 31PICT-3 113905205AJ
(Eng 1-2699)
113905205AL
(eng 2700-3000) 181 1600 1971 125 130z 65 Non-US Thing AG engine Aux fuel jet-50
VW 313-1/2 31PICT-3 181905205 181 1600 1971 125 130z 65 Non-US Thing AG engine Aux fuel jet-50
M63 MILITARY SUPPRESSION
VW 320-1,2,3 30PICT-3 111905205AA BUG 1200 08/70 112.5 170w 55 European 1200 FROM ENG D0675001
aux fuel jet 40
VW 321-1/2 31PICT-3 113905205AJ Bug 1300 1971 130 110z 55 Non-US manual Aux fuel jet-50, M527
VW 322-1/2 31PICT-3 113905205AK Bug 1300 1971 130 110z 55 Non-US autostick Aux fuel jet-50, M527
VW 323-1/2 31PICT-3 113905205AJ Ghia 1300 1971 135 140z 65 Non-US manual Aux fuel jet-50, M527
VW 324-1/2 31PICT-3 113905205AK Ghia 1300 1971 120 140z 65 Non-US autostick Aux fuel jet-50, M527
VW 325-2 34PICT-3 113905205AN BUG 1600 1972 130 75z 55 USA Manual
VW 325-3 34PICT-3 113905205AN BUG 1600 1973 127.5 75z 55 California manual
VW 325-4 34PICT-3 113905205AN BUG 1600 1973 127.5 75z California manual
VW 326-1 34PICT-3 113905205AJ GHIA 1600 1972 127.5 80z 60 USA manual
VW 326-3 34PICT-3 113905205AN GHIA 1600 1972 12705 70z 55 USA manual to AE 0628298
VW 327-1/2 34PICT-3 211905205Q BUS 1600 1971 125 60z 57.5 USA
VW 328-1 34PICT-3 113905205AJ BUG 1600 08/70 X130 60Z 65 Non-US manual AD engine, M527
VW 329-1 34PICT-3 113905205AK BUG 1600 08/70 X130 60Z 65 Non-US autostick AD engine, M527
VW 330-1 34PICT-3 113905205AJ Ghia 1600 08/70 X130 80Z 65 Non-US manual AD engine, M527
VW 331-1 34PICT-3 113905205AK Ghia 1600 08/70 X130 80Z 65 Non-US autostick AD engine, M527
VW 332-1 34PICT-3 211905205R BUS 1600 1971 125 60z 60 M527
VW 343-2/3 34PICT-3 113908205AH BUG 1600 1973 127.5 75z 55 California autostick
VW 343-4 34PICT-3 113908205AH BUG 1600 EARLY/MID
DISTRIBUTOR CHANGED AT AH0098884
043905205D late 73
VW 344-2 34PICT-3 113905205AH Ghia 1600 127.5 70z 55 California Autostick
VW 355-1 34PICT-3 113905205AJ BUG 1600 01/06/71 X130 60Z G65 Non-US manual AD engine
FROM ENG AD257544-AD360022.
VW 355-2 34PICT-3 113905205AL
043905205 BUG 1600 08/71 X130 60Z G55 Non-US manual AD engine
FROM ENG AD360023
VW 355-3 34PICT-3 043905205 BUG 1600 08/71 130 60z 55 Non-US manual AS engine,
PAPER AIR CLEANER
VW 356-1 34PICT-3 113905205AK BUG 1600 08/71 130 60z 55 Non-US autostick AD engine,
VW 356-2 34PICT-3 113905205AM
043905205A BUG 1600 08/71 130 60z 55 Non-US autostick AD engine,
FROM ENG AD360023
VW 356-4 34PICT-3 043905205A BUG 1600 08/71 130 60z 55 Non-US autostick AD/AS engine, FROM ENG AD360024+AS
VW 357-1 34PICT-3 113905205AJ Ghia 1600 08/71 X130 80Z 65 Non-US MANUAL AD engine, ENG AD257544-AD360022
VW 357-2 34PICT-3 113905205AL
043905205 Ghia 1600 08/71 X130 80Z 55 Non-US MANUAL AD engine, FROM ENG AD360023
VW 358-1 34PICT-3 113905205AK Ghia 1600 08/71 X130 80Z 65 Non-US AUTO AD engine, ENG AD257544-AD360022
VW 358-2 34PICT-3 113905205AM
043905205A Ghia 1600 08/71 X130 80Z 55 Non-US AUTO AD engine, FROM ENG AD360023
VW 359-1 34PICT-3 113905205AL Bus 1600 08/71 X125 60Z G60 Non-US manual AD engine, ENG AD290641-AD350045
VW 359-2 34PICT-3 211905205S
043905205B (AS eng) Bus 1600 08/71 X125 60Z G55 Non-US manual AD engine, FROM ENG AD350046 &AS eng
VW 360-1/2 31PICT-3 113905205AL Bug 1300 1972 130 110z 52.5 Non-US manual Aux fuel jet-45,
FROM ENG AB350001
VW 361-1/2 31PICT-3 113905205AM Bug 1300 1972 130 110z 52.5 Non-US autostick Aux fuel jet-45,
FROM ENG AB350001
VW 362-1 31PICT-3 113905205AL Ghia
Bus 1300 01/71 x130 110z g60 Non US Aux fuel jet - 50
FROM ENG AB 155180 (Ghia)
Also Italian-Spec Bus M252
VW 362-2 31PICT-3 113905205AL Ghia 1300 1972 130 125z 60 Non-US manual Aux fuel jet-45, FROM ENG AB155180 M252
VW 363-1 31PICT-3 113905205AM 1300 1972 x125 140z 65 Non-US Autostick
VW 363-2 31PICT-3 113905205AM Ghia 1300 1972 130 125z 60 Non-US autostick, aux fuel 45
FROM ENG AB350001
VW 364-1 31PICT-3 113905205AL 1300 1972 x130 110z 55 Non-US Manual
VW 365-1 31PICT-3 113905205AL 181 1300 1972 x130 110z g65 Non-US Thing
VW 365-2 31PICT-3 113905205AL 181 1600 08/71 125 110z 55 Non-US Thing AG engine aux fuel 45
VW 366-1 31PICT-3 181905205 181 1600 8/71 x125 110z 55 Non US Thing M63 aux fuel 45
VW 367-1 34PICT-3 113905205AL
181905205 Bus 1600 08/71 X125 60Z G60 Non-US manual AD290641-AD350045
(with M623 M632)
VW 367-2 34PICT-3 211905205S
043905205B (AS eng) Bus 1600 08/71 X125 60Z G55 Non-US manual AD engine, FROM ENG AD350046 & AS eng
VW 377-1
VW 377-2 34PICT-3 113905205AN BUG 1600 1973 127.5 75z 55 USA Manual
VW 378-1 34PICT-3 113905205AN Ghia 1600 1973 127.5 70z 55 USA Manual From AE 0627299
VW 390-1 31PICT-4 043905205 BUG 1300 1973 x130 110z 52.5 Non US Manual aux fuel 45
VW 394-1 31PICT-4 043905205A BUG 1300 1973 x130 110z 52.5 Non US Autostick aux fuel 45
VW 401-1 34PICT-3 043905205 181 1600 4/73 x127.5 75z 55 Non US Thing
VW 402-1 34PICT-3 043905205 181 1600 4/73 x127.5 75z 55 Non US Thing M63
VW 404-1 34PICT-3 043905205 181 1600 3/73 x127.5 75z 55 US Thing M157
VW 410-1 34PICT-3 113905205AN
043905205 BUG 1600 1973 127.5 70z 55 USA Manual
could be set up for either SVDA or DVDA
VW 411-1 34PICT-3 113905205AN
043905205C BUG 1600 1973 127.5 75z 55 California manual
VW 412-1 34PICT-3 113908205AH 043905205A BUG 1600 1973 127.5 75z 55 USA Autostick
VW 427-1 34PICT-3 043905205 BUG 1600 1974 127.5 70z 55 USA Manual
VW 428-1 34PICT-3 043905205A BUG 1600 1974 127.5 75z 55 USA Autostick
VW 429-1 34PICT-4 043905205C BUG 1600 1974 127.5 60z 55 California manual
VW 430-1 34PICT-4 043905205A BUG 1600 1974 127.5 60z 55 California autostick
VW 449-1 31PICT-4 043905205 BUG 1300 08/73 130 110z 52.5 Non-US manual AR engine
VW 450-1 31PICT-4 043905205A BUG 1300 08/73 130 110z 52.5 Non-US autostick AR engine
VW 472-1 30PICT-3 043905205 BUG 1200 06/74 112.5 170w 50 European 1200 FROM D1268063
VW 523-1 34PICT-4 043905205 K BUG 1600 08/75 127.5 60z 55 Non-US manual AS engine
VW 524-1 34PICT-4 043905205 A BUG 1600 08/75 127.5 60z 55 Non-US autostick AS engine
VW 525-1/3/4 30PICT-3 043905205 K BUG 1200 08/75 112.5 170w 47.5 European 1200 , aux fuel 40
FROM ENG D1347143, M88
(data in red added by Andrew P, in blue are most recent additions by Andy T.)
Special thanks to Moby5153 on the British VZi Forums and 1500king on KombiClub for much of the Non-USA information, and to Everett Barnes and Roger N. and DrDarby on TheSamba.com for the other dates, including the 1967/earlier VW Technical Bulletin Engine data supplements (
http://www.thesamba.com/vw/archives/man ... ins/m1.php) that much of this information was compiled from, plus the German-language Technical Bulletins found at:
http://vwbus2.dyndns.org/bulli/michaelk ... frame.html
This is not a complete listing. Anyone with additional or missing information that could be added to this chart, email me at
glutamodo@AOL.com. Technical bulletins regarding engine data from 1968 and newer are especially desired.
Last updated 07-14-2011 Thanks! -Andy T.
_________________
It all belongs to the Lord in the end because you can't take it with you, so let the Lord make the decisions you feel troubled to make. Hope you are having a great day!
Back to top
View user's profile Send private message Send e-mail Gallery Classifieds Feedback
