also ......
es gibt von engle 3 arten von FK 89 Nockenwelllen
1.
Engle Fk-89 Camshaft
The Fk-89 Makes Tons Of Power. Very Popular Cam With The Guys Running Hot Street Engines And The Racers. .416" Lift And 328 Degrees Duration. With 1.4:1 Rockers You Will Have 582" Lift. This Is The Racers Choice.
2.
Eagle Drag Race Cam
(FK-89) Adv. Duration 322° / Dur. @ .050" 274° / Lift @ cam .398" / Lift w/1.1:1 Rocker Arms .437" / Lift w/1.25:1 .498" / Lift w/1.4:1 .557" / Lift w/1.5:1 .597". If you're looking for maximum quarter mile performance, this is the cam series for you. Eagle Drag Race Cams have been designed for use with high lift rockers, dual springs, and a heavy foot. For your convenience we have listed the valve lifts with 1.1:1 ratios and also when using the three most popular high lift rocker arm ratios. Eagle Drag Race Cams are ground on 107 degree lobe centers on special oversize billets. Each cam is heat treated, Parkerized, and shipped with new bolts and cam locks. Eagle Drag Race Came are for the serious racer. Others need not apply!
3.
Eagle Drag Race Cam
(FK-89) Adv. Duration 328° / Dur. @ .050" 278° / Lift @ cam .407" / Lift w/1.1:1 Rocker Arms .447" / Lift w/1.25:1 .509" / Lift w/1.4:1 .570" / Lift w/1.5:1 .611". If you're looking for maximum quarter mile performance, this is the cam series for you. Eagle Drag Race Cams have been designed for use with high lift rockers, dual springs, and a heavy foot. For your convenience we have listed the valve lifts with 1.1:1 ratios and also when using the three most popular high lift rocker arm ratios. Eagle Drag Race Cams are ground on 107 degree lobe centers on special oversize billets. Each cam is heat treated, Parkerized, and shipped with new bolts and cam locks. Eagle Drag Race Came are for the serious racer. Others need not apply!
nun stehe ich vor der qual der wahl .... bin bisher immer fk 89 (Nr.1) gefahren !!!!!
könnte mich bitte mal jemand aufklären =? da ich das nicht so ganz auf die kette bekomme
mfg
arndt
