Käfer, Bus... Schlüsselanhänger aus Edelstahl
Verfasst: So 29. Dez 2013, 16:28
Laser cut Stainless steel Keyrings
VW Beetle (64x33x2mm) http://www.ebay.de/itm/111280561517
VW T1 Samba Bus (63x30x2mm) http://www.ebay.de/itm/111258542125
VW Golf GTI Mk1 (65x26x2mm) http://www.ebay.de/itm/111280566510
Price EUR 9,95 per item
P&P to Germany EUR 2,80 International Tracked Postage (Registered&Priority item)+ EUR 0,25 per each additional item.
(Due to regulations of Deutsche Post all the registered items after 01.01.2014 are priority items mandatory).
Dear friends! We have the pleasure to present you our first set of 8 different models of
laser cut and brushed high quality stainless steel keyrings.
They are all 63-65mm (2.5 inches) long including the little tail ring,
but the size of each one varies in height 26-33mm (1.0-1.3 inches) and weigh 17-23gr.
The thickness of 2mm (0.08") is just perfect to give the impression and the feeling of a massive and solid product.
Our own experience proves that these are the right dimensions for such a keyring.
Anyway, please, make sure that they meet your requirements, before ordering!
Using it under normal conditions, you will have an everlasting stylish keyring for your classic or modern ride, that will never wear out or bend.
For more info follow the links or send a PM. Welcome to our other items!
Thank you!!!
PS - Excuse me for writing in English! If the German is a must in this sub-forum, I'll manage to translate it.
If i break the rules of the forum, expect advise from the administration. Thanks!
Thank you!!!
