1200 Nitrous fastback (parts stage)
Verfasst: Sa 19. Jan 2013, 13:57
Hey guys,
My name is jesse and I live in the land of European bugins, Belgium.
Having build a 1200 turbo engine before I wanted back in the game.
Walter inspired me to build another engine.
I looked at what parts laying around and came up with this....
Type 3 dual relief U case
The case has some kind of vw recycling logo on it so I guess its been reconditioned ones.
I´ll have it looked over. don't know how far I´ll go modifying the case yet.
Original crank
this one has allready been looked over, drilled for 8 dowel pins and dynamicaly balalnced with flywheel, pulley, pressure plate...
200 mm flywheel 8 doweled
The flywheel is still full weight, I allways had the feeling I needed it to get of the startline. Would it be wise to lighten it in a heavy car?
I´ll use the 4 puck I used in the Turbocar, I liked it
Kennedy stage 1 pressure plate
Powerpuley with 36-1 teeth
Original rods reconditioned
Thinking of lightening and polishing the rods.
Original cilinders for big hole in case, late
original pistons with dome
1300 dual port cilinderheads with Second spark plug
Will flycut the heads as far as the second sparkplug allows it. Think it will be around 8.5.
35,5 and 32 mm SS valves
Dual gene berg valve springs
Wizard of NOS progressive controlled nitrous kit rated 150 HP max
Something open for debate...
The camshaft
I was thinking of a FK 44 on a wider lobecenter, like 110.
Maybe 45 on the exhaust.
1.3 or 1.4 rockers
This entire contraption will be fed by liquid propane, even the nitrous part.
Vaporizer will be heated by engine oil and will work as oilcooler.
Exhaust will be a cheap 4 in 1 header at first, might need something bigger. We´ll see what the bank says.
it will all be mounted in a 66 fastback and be driven everywhere just like I did the 1200 engine
The plan is to visit, EBI, the 1200 dynochallange, Bugrun, SCC and DDD this year.
Now let me hear your thoughts and ideas on the parts.
Jesse
Original crank
The camshaft
1.3 or 1.4 rockers
Jesse
